Jun 12, 2022Guru - Experienced User
Enable Email Logging and Router Reboots
NOTICE:
For ANY users seeing mysterious reboots of there 7 or 8 series RBR routers rebooting at random or at specific time frames, we'd like to ask you to enable Email Logging of the RBR and config...
- Jun 20, 2022
Ok, enabling email logs seems to help stop the RBR mysterious rebooting. Mines been online for 4+ days:
Uptime would have been more however we had a brown out last Wednesday.
Jun 20, 2022Guru - Experienced User
- cdp1276Jun 21, 2022Star
I've been up for 15+ days and agree something has helped stabilize at the moment as I was almost every 12 hours previously and I knew there was no need to go into AP mode as my setup used to work solid for years!
- FURRYe38Jun 21, 2022Guru - Experienced User
Glad it's working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
- UlkaFettJun 21, 2022Initiate
FURRYe38:
Thanks for continuing to support us at this level. Enabling e-mail logging has corrected the reboot issue for me in the same manner as the others. this is the best the system has worked for me since version 4 was released. I am currently on V4.6.8.2 with this correction in place.
