Jun 12, 2022Guru - Experienced User
Enable Email Logging and Router Reboots
NOTICE:
For ANY users seeing mysterious reboots of there 7 or 8 series RBR routers rebooting at random or at specific time frames, we'd like to ask you to enable Email Logging of the RBR and config...
- Jun 20, 2022
Ok, enabling email logs seems to help stop the RBR mysterious rebooting. Mines been online for 4+ days:
Uptime would have been more however we had a brown out last Wednesday.
Jul 20, 2022Guru - Experienced User
Be sure to make a new back up since you FR and set up from scratch.
Yes NG knows of this issue with the RBR reboot, logging and email logging.
You have a lot of device so I guess you need to email log hourly. You can try disabling email logging and see if the system continues to work ok. I found that after I had email logging enabled and the system worked for 3 days, I just unchecked the disable box for email logging and the system continued to work with out any reboots. Only when I FR and setup again did the reboots return.
Ya, no idea when that fix will come in.
tiangao
Jul 20, 2022Aspirant
Considering the work to redo the set-up from scratch, I have obviously done a parameters backup.
The time spent on this is worth to me more than the hardware, so I am not touching anything until the next firmware !
Hope that Netgear learns from this and put more ressources into firmware development.
At that price point, we are expecting stuff that just work.
- FURRYe38Jul 20, 2022Guru - Experienced User
Ya we get that.
Just letting you now about the back up and email.
Here's hoping though.
