Jun 12, 2022Guru - Experienced User
Enable Email Logging and Router Reboots
NOTICE:
For ANY users seeing mysterious reboots of there 7 or 8 series RBR routers rebooting at random or at specific time frames, we'd like to ask you to enable Email Logging of the RBR and config...
- Jun 20, 2022
Ok, enabling email logs seems to help stop the RBR mysterious rebooting. Mines been online for 4+ days:
Uptime would have been more however we had a brown out last Wednesday.
mcgarryv
Aug 10, 2022Tutor
I am delighted to have found this page. Thanks very much for the excellent suggestions.
Like many, my Orbri RBR750 was randomly rebooting a few times a day.
I did the following: 1) Configured the gmail setings correctly 2) Enabled emailing of the log day 3) Updated to the latest F/W.
My router has bee running for > 3 days now without issue:
Basic Information
Firmware Version: V4.6.8.5_2.1.9
dumaos: v3.0.410
seal: v2.1.5.37-2
seal_services: v2.1.5.12-0
armor-bd: v2.2.100.3
spc-circle: v3.25.0.2
CPU Load: 12.80%
Memory Usage(Used/Total): 331 MB/874 MB
System Uptime: 3 days 10:06:11
- FURRYe38Aug 10, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡 - cdp1276Aug 10, 2022Star
And just to give you more confidence of stability mine is at 39 days and the only reason not longer is I updated the latest firmware but before this was up for weeks as well...
Basic Information
dumaos: v3.0.410
seal: v2.1.5.37-2
CPU Load: 11.65%
Memory Usage(Used/Total): 392 MB/874 MB
System Uptime: 39 days 12:06:19
Very nice. 👍
