avalpert
Sep 04, 2020Aspirant
Enabling AX Not Available - RBR750
Hi, I can't seem to figure out how enable (or check that it is) the AX features on my Orbi RBR750. In the wireless settings there is no checkbox next to 'Enable AX' (see attached picture) and my comp...
avalpert
It's Firmware 3.2.16.6_1.4.4. Attached is a screenshot of the homepage
Sep 04, 2020Guru - Experienced User
Now navigate to Basic/Wireless Settings. What do you see here?
- avalpertSep 04, 2020Aspirant
Screenshot attached.
- FURRYe38Sep 04, 2020Guru - Experienced User
The two check boxes next to Enable 2G and 5G are the AX mode enable boxes. When these are checked, AX mode is enabled. Removing the check in the boxes then applying the change disable AX mode.
I see, then can you think of a reason my computer (with an AX wireless card) would think the access point is an AC?
