GLO
Feb 03, 2025Tutor
Enabling Guest network impacts main wifi users receiving 169.x.x.x
Hi, I am experiencing very unusual behavior on my RBRE960 and 2x RBSE960 (now with ethernet back hauls) I have deduced that when I enable guest wifi, Iphones reconnecting to my main wifi, are s...
Feb 04, 2025Guru - Experienced User
How are the RBS ethernet connected to the RBR? Directly or is there a LAN Switch inbetween? If there is a LAN switch, please give brand and model#.
What firmware version is loaded on the system?
What region are you located?
GLO wrote:
Hi,
I have deduced that when I enable guest wifi, Iphones reconnecting to my main wifi, are showing connected but no internet connection. They reflect a 169.x.x.x IP address and naturally no data passes.
My IOT Wifi channel also has trouble connecting I have noticed.
Many other wifi enabled devices remain connected successfully to the same main SSID.
When I disable guest Wifi, the issue seems to go away for the most part.
Any tips apart from disabling Guest Wifi permanently.
Thanks in advance.
- GLOFeb 11, 2025Tutor
Hi, The satellites are connected by ethernet back haul to a Netgear JGS524PE.
- FURRYe38Feb 11, 2025Guru - Experienced User
Ok that's a smart managed switch, these kinds of switches are known to cause problems in between the RBR and RBS.
Any chance you can put in a non managed switch? NGs GS105 or GS305 series would work.
- GLOFeb 12, 2025Tutor
I had sought out the Netgear Smart switches, to start leveraging the VLAN capabilities of the Orbi963.
Who else has had these problems?
I forgot to mention im in Australia and running V7.2.6.31_5.0.24
