GLO
Feb 03, 2025Tutor
Enabling Guest network impacts main wifi users receiving 169.x.x.x
Hi, I am experiencing very unusual behavior on my RBRE960 and 2x RBSE960 (now with ethernet back hauls) I have deduced that when I enable guest wifi, Iphones reconnecting to my main wifi, are s...
Feb 04, 2025Guru - Experienced User
How are the RBS ethernet connected to the RBR? Directly or is there a LAN Switch inbetween? If there is a LAN switch, please give brand and model#.
What firmware version is loaded on the system?
What region are you located?
GLO wrote:
Hi,
I have deduced that when I enable guest wifi, Iphones reconnecting to my main wifi, are showing connected but no internet connection. They reflect a 169.x.x.x IP address and naturally no data passes.
My IOT Wifi channel also has trouble connecting I have noticed.
Many other wifi enabled devices remain connected successfully to the same main SSID.
When I disable guest Wifi, the issue seems to go away for the most part.
Any tips apart from disabling Guest Wifi permanently.
Thanks in advance.
GLO
Feb 11, 2025Tutor
Hi, The satellites are connected by ethernet back haul to a Netgear JGS524PE.
- FURRYe38Feb 11, 2025Guru - Experienced User
Ok that's a smart managed switch, these kinds of switches are known to cause problems in between the RBR and RBS.
Any chance you can put in a non managed switch? NGs GS105 or GS305 series would work.
- GLOFeb 12, 2025Tutor
I had sought out the Netgear Smart switches, to start leveraging the VLAN capabilities of the Orbi963.
Who else has had these problems?
- FURRYe38Feb 12, 2025Guru - Experienced User
Common problem when using any kind of smart/managed switch with ethernet connected RBS. Those switches don't allow full traffic between the RBR and RBS when non managed switches do.
is the RBR in router mode or AP mode?
