akhilstyle
Mar 15, 2022Tutor
Ethernet Backhaul - Connected Orbi Issue
I have an RBK753 system. With a router and 3 satellites. The satellites are connected via ethernet backhaul to a switch along with the router. I have noticed that usually the 3 satellites show th...
Mar 15, 2022Guru - Experienced User
Is the switch connected to the back of the RBR?
What is the Mfr and model# of the ethernet switch in the configuration?
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System 📡
What CAT# cable is being used? CAT6 is recommended.
- akhilstyleMar 15, 2022TutorHi,
Thanks for your reply
RBR 750 - firmware - 4.6.5.14
RBS 750 - firmware - 4.6.5.14
ISP modem - open reach g fast modem model MT992
Switch - TP-Link TL-SG108S, 8 Port Gigabit Ethernet Network Switch
The modem is plugged into the routers wan port. One of the lan ports is connected to the switch. Then all of the satellites connect to the switch.
All CAT5 cable.
Thanks- FURRYe38Mar 15, 2022Guru - Experienced User
akhilstyle wrote:
Hi,
Seen others with this brand having problematic issues with Orbi systems. Has Green ethernet features that can cause problems:
- Green Ethernet technology saves power consumption
All CAT5 cable. < Cat6 LAN cables are recommended at minimum.- akhilstyleMar 15, 2022TutorThanks.
Are there any examples of unmanaged switches that work?
Thanks
