akhilstyle
Mar 15, 2022Tutor
Ethernet Backhaul - Connected Orbi Issue
I have an RBK753 system. With a router and 3 satellites. The satellites are connected via ethernet backhaul to a switch along with the router. I have noticed that usually the 3 satellites show th...
akhilstyle
Mar 15, 2022Tutor
Hi,
Thanks for your reply
RBR 750 - firmware - 4.6.5.14
RBS 750 - firmware - 4.6.5.14
ISP modem - open reach g fast modem model MT992
Switch - TP-Link TL-SG108S, 8 Port Gigabit Ethernet Network Switch
The modem is plugged into the routers wan port. One of the lan ports is connected to the switch. Then all of the satellites connect to the switch.
All CAT5 cable.
Thanks
All CAT5 cable.
Thanks
Mar 15, 2022Guru - Experienced User
akhilstyle wrote:
Hi,
Seen others with this brand having problematic issues with Orbi systems. Has Green ethernet features that can cause problems:
- Green Ethernet technology saves power consumption
All CAT5 cable. < Cat6 LAN cables are recommended at minimum.
- akhilstyleMar 15, 2022TutorThanks.
Are there any examples of unmanaged switches that work?
Thanks- FURRYe38Mar 15, 2022Guru - Experienced User
NG GS-105/108v4 and GS308v3, D-Link DGS-105/108 and HP ProCurve 1400/1800 series switches work for Orbi systems.
Thank you so much - I will give it a go with one of the switches that you recommend.
If I use the current (green/energy saving) TP Link switch on one of the satellites (to connect other devices) will that be ok as it is not between the router and satellite? For example if I have the router connected to the satellite via one of the switches that you mentioned, and then plug in the tp-link switch to the other ethernet port on the satellite - to connect a few other devices - would this be ok? or would I have a similar issue?
ThanksAkhil
