Aizal
Nov 30, 2021Aspirant
Ethernet backhaul cause satellite to disappear and everything connected to router
I have RBK752 in AP mode connected to my existing network and everything is fine. The issue starts when I connected the satellite for ethernet backhaul. What happened was I cannot see the satelli...
- Nov 30, 2021
Yes, any RBS ethernet connected, switch or not, needs to be connected behind the RBR. Router or AP mode.
Aizal
This is the configuration following that 3rd picture which doesn't work.
RBR < C3150v2 > SG108E > RBS
I have ethernet backhaul working by unplugging the SG108E from C150v2 and connect it direct to RBR.
C3150v2 > RBR > SG108E > RBS
Nov 30, 2021Guru - Experienced User
Ok, Thats the only configuration that will work for etherent connected RBS with switch(s).
- AizalNov 30, 2021Aspirant
Yeah, I guess I can't use the main router as a switch for ethernet backhaul, it must be directly connected to RBR or through an actual switch which connects both of them and not parallel.
- FURRYe38Nov 30, 2021Guru - Experienced User
Ya you can't use that configuration. Gotta be directly behind the RBR in series.
