Aizal
Nov 30, 2021Aspirant
Ethernet backhaul cause satellite to disappear and everything connected to router
I have RBK752 in AP mode connected to my existing network and everything is fine. The issue starts when I connected the satellite for ethernet backhaul. What happened was I cannot see the satelli...
- Nov 30, 2021
Yes, any RBS ethernet connected, switch or not, needs to be connected behind the RBR. Router or AP mode.
Aizal
Yeah, I guess I can't use the main router as a switch for ethernet backhaul, it must be directly connected to RBR or through an actual switch which connects both of them and not parallel.
Nov 30, 2021Guru - Experienced User
Ya you can't use that configuration. Gotta be directly behind the RBR in series.
