EyalS
Aug 28, 2021Tutor
Ethernet backhaul not working after upgrade to V4.6.3.9
After upgarding to V4.6.3.9, I'm unable to connect my 3 RBS850 satellites to the RBR850 router through a switch. Factory reset ALL the devices didn't help. If I try to connect them directly, it w...
- Jan 29, 2022
Looking at the release notes of V4.6.3.9, it seems like moving the backhaul from LAN port 1 to LAN port 2 solved the problem.
I wonder how many customers were frustrated with this problem, while the bug was known to Netgear....
As said, this was my last Netgear product.
V4.6.3.9 Release Notes:
Enhancement: Updated wireless parameters as suggested by RF Team
Bug Fixes:
Unexpected reboot of Orbi Router.
Issue with IPTV/Multicast when PPPoE is enabled on WAN
Logs (GUI) only shows the activity that happened within the last 3 hours, not the entire router up-time logs.
Guest WiFi disconnects internet after 1 minute
RBR850 LAN port 1 became inaccessible as ethernet backhaul in AP mode
Potential satellite connection issues
Observed crash in RBS750
Factory Reset on Orbi GUI sometimes not working
Orbi App cannot connect to router when configured LAN IP address is 198.19.0.1
GUI Speed Test and Orbi app Speed Test do not show the Download Speed. (Community, Please confirm this works.)
WAN connection lost after 24 hours with magenta LED on router. (Community, Please confirm this works.)
Aug 28, 2021Guru - Experienced User
How long are you waiting after you connect to the switches in between the RBR and RBS?
For the GS308E, log in and disable any and ALL IGMP protocols.
It doesn't have any Green Ethernet features that I can tell as this can cause problems as well.
NG GS-105/108v4, D-Link DGS-105/108 and HP ProCurve 1400/1800 series switches work for Orbi systems that I've tested on v4.
EyalS
Jan 29, 2022Tutor
Thanks, I bought:
- NETGEAR 8-Port Gigabit Ethernet Plus Switch (GS308E)
- D-Link Ethernet Switch, 8 Port Gigabit Unmanaged Metal Fanless Desktop or Wall Mount Design (DGS-108)
Tried with both, but it didn't work, couldn't see the sattelites in the router administration UI.
Spent hours, trying to figure out what is the problem.
And than... I updated yesterday the firmware to Version v4.6.7.5 (which is actually only on the forum, the router update didn't detect it).
Now, I can see the 3 satellites in the router web UI, BUT accessing any of the satellites directly, shows it as un-connected...
I'm getting: "Move your Orbi Satellite closer to your Orbi network to improve connection."
and it seems like changes I do on the main router do not propagate to the satellites...
It feels like there are so many bugs on their software. I probably need to wait for the next update...
After so much time, and money wasted, I will never by a Netgear product again.
