mjsmith1568
Nov 25, 2021Aspirant
Ethernet Backhaul on AX6000 (RBK854)
 Hi Everyone. I'm looking to replace my current Velop 802.11ax mesh system with another and have a specific question on wired backhaul. Velop support this, but the system must first be setup wirelessl...
- Nov 27, 2021
 mjsmith1568 wrote:
 Hi Furry, Before I accept as a solution, I just want to make sure I understand the process correctly. Yes. 1. Near the router, plug in the satellite and setup wirelessly according to the instructions. Yes, or after the RBS is wirelessly synced, plug an ethernet cable in between the RBR and RBS while near the RBR to make sure the RBS is working ethernet connected. 2. completely unplug the satellite, diconnecting from power, and move to its intended room near power and ethernet connection. Yes. 3. Connect to power and ethernet and when the satellite powers back up, it will be still be joined to the network and you won't need to set it up again. Yes. Is this basically correct? Yes. I had thought that this limitation meant that a satellite always needed a wireless connection to at least one other satellite/router for the wired backhaul channel to work. No.
mjsmith1568
Nov 27, 2021Aspirant
Hi Furry,
Thanks,
Matthew
Nov 27, 2021Guru - Experienced User
mjsmith1568 wrote:
Hi Furry,
