jjlsetter
Nov 03, 2022Aspirant
Ethernet Backhaul Question with the RBK753
I'm considering getting the RBK753 for house and I have a question about setting up the ethernet backhaul. Can I have one of the satellite's connected to the router via ethernet backhaul and the seco...
Nov 04, 2022Guru - Experienced User
Yes you can do that. I've done it with a set of RBK750's and it worked fine
jjlsetter
Nov 07, 2022Aspirant
Ok so here’s the plan:
ONT > RBR750 > Unmanaged Switch > RBS750 1 (wired backhaul)
Then
RBR750 > RBS750 2 (wireless backhaul)
It shouldn’t make a difference that the wired satellite is connected via the switch, correct?
- pkgaddNov 07, 2022Luminary
That works just fine, a switch is basically invisible to either side anyways.
- CrimpOnNov 07, 2022Guru - Experienced User
That is correct. It shouldn't make a difference. But, sometimes it does. Going back 5-6 years, there have been reports of "unmanaged switches" affecting satellite connection to the router. If there is a problem, it will emerge quickly and can be diagnosed by temporarily removing the switch and connecting the satellite directly. When that fixes the problem, then (duh) the switch is the culprit.
- FURRYe38Nov 07, 2022Guru - Experienced User
Can depend on brand and model of un-managed switch can cabling used though. Most Un-managed switches should work. Green Ethernet switches features can be a factor.
