Peanut_Butter
Mar 10, 2022Aspirant
Ethernet Backhaul
Hi Everyone. I've decided to create a wired backhaul connection to my Orbi mesh system (RBK753). Basically that's my setup ("star topology", very simple): 1) Changed my Virgin Hub 3.0 f...
- Mar 10, 2022
Peanut_Butter wrote:
How can I certify that my Orbi satellites are receiving the internet data from the router over the wired backhaul setup I've done in the steps above? Whilst the ethernet cables are plugged in the satellites, I have a strange feeling that the wireless could be prevailing over my wired backhaul setup (I might be wrong).
On the opening page of the Orbi app, the network diagram shows satellites connected to the router with a dotted line (for WiFi connection) and with a solid line ( for wired connection).
Or, the Orbi web interface (http://orbilogin.net), Attached Devices page lists the satellites at the top and describes the backhaul connection with pictures and words ('wired').
JohnnyWick
Mar 14, 2022Aspirant
Thanks so much for clarifying, I checked the Orbi app and I could confirm the continuous line linking the router and satellites. Everything looking perfect! :-) Much appreciated for your help! :-)
- FURRYe38Mar 14, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
