devdeep
Jun 23, 2021Guide
Ethernet CAT 5 patch cable suitability
I have an ethernet patch CAT 5 cable running from the Router downstirs to the room above it (connected to Asus router in AP Mode). I have two Orbi satallites - one at the end of the house downstairs ...
- Jun 23, 2021
CAT5 is rated for 100Mpbs. CAT5e started to support 1000Mpbs. I highly recommend CAT6. Been using it for years. I have CAT6A in wall and it's rated for 10Gb for if and when I can get into that speed. So 6 or 7 and you'll be fine.
Jun 23, 2021Guru - Experienced User
devdeep
Jun 23, 2021Guide
FURRYe38 wrote:CAT5 is rated for 100Mpbs. CAT5e started to support 1000Mpbs. I highly recommend CAT6. Been using it for years. I have CAT6A in wall and it's rated for 10Gb for if and when I can get into that speed. So 6 or 7 and you'll be fine.
Thanks. I guess will consider 7 as it is only slightly more than price of 6. PAin really! Will have to go through "re-threading" the cable again! I guess, in the end it is worth it!
