Dazza762
Feb 08, 2022Luminary
Ethernet Doesn’t Have A Valid IP Configuration
Hi. I'm having issues with a wired connection from a satalite in my RBK753 system. It keeps losing connection and stating it doesn't have a valid IP configuration. The connected laptop is a Windows 1...
Feb 08, 2022Guru - Experienced User
If you swap the satellites or computers around, does the issue stay specific to that satellite or to the location?
Dazza762
Seems to be specific to the satallite. Haven't swaped the satallites round but I've connected several devices to the other satallite via wired connection without issue.
- plemansFeb 08, 2022Guru - Experienced User
What firmware is on the router and what version on the satellites?
Have you tried factory resetting the satellite and re-syncing it?
