Dazza762
Feb 08, 2022Luminary
Ethernet Doesn’t Have A Valid IP Configuration
Hi. I'm having issues with a wired connection from a satalite in my RBK753 system. It keeps losing connection and stating it doesn't have a valid IP configuration. The connected laptop is a Windows 1...
Dazza762
Seems to be specific to the satallite. Haven't swaped the satallites round but I've connected several devices to the other satallite via wired connection without issue.
Feb 08, 2022Guru - Experienced User
What firmware is on the router and what version on the satellites?
Have you tried factory resetting the satellite and re-syncing it?
- Dazza762Feb 08, 2022Luminary
V4.6.5.14 on everything. I have deleted it from the system and added it as a new satallite though.
It's not showing as out of sync on the router website and backhaul status is "good"
- plemansFeb 08, 2022Guru - Experienced User
You could try this version of the firmware.
See if it helps with stability.
New - RBR750 / RBS750 Firmware Version v4.6.7.5 Re... - NETGEAR Communities
