Dazza762
Feb 08, 2022Luminary
Ethernet Doesn’t Have A Valid IP Configuration
Hi. I'm having issues with a wired connection from a satalite in my RBK753 system. It keeps losing connection and stating it doesn't have a valid IP configuration. The connected laptop is a Windows 1...
Feb 08, 2022Guru - Experienced User
What firmware is on the router and what version on the satellites?
Have you tried factory resetting the satellite and re-syncing it?
Dazza762
V4.6.5.14 on everything. I have deleted it from the system and added it as a new satallite though.
- Dazza762Feb 08, 2022Luminary
It's not showing as out of sync on the router website and backhaul status is "good"
- plemansFeb 08, 2022Guru - Experienced User
You could try this version of the firmware.
See if it helps with stability.
New - RBR750 / RBS750 Firmware Version v4.6.7.5 Re... - NETGEAR Communities
Mmmm. I'm reticent to try newer firmware until it's showing as the current version on the Netgear support site for the product and last time i checked, that was the version I'm currently using. No issues with any other connections on any other devices so I'd rather try specific fixes for this one ethernet connection if possible.
