Dazza762
Feb 08, 2022Luminary
Ethernet Doesn’t Have A Valid IP Configuration
Hi. I'm having issues with a wired connection from a satalite in my RBK753 system. It keeps losing connection and stating it doesn't have a valid IP configuration. The connected laptop is a Windows 1...
Dazza762
It's not showing as out of sync on the router website and backhaul status is "good"
Feb 08, 2022Guru - Experienced User
You could try this version of the firmware.
See if it helps with stability.
New - RBR750 / RBS750 Firmware Version v4.6.7.5 Re... - NETGEAR Communities
- Dazza762Feb 08, 2022Luminary
Mmmm. I'm reticent to try newer firmware until it's showing as the current version on the Netgear support site for the product and last time i checked, that was the version I'm currently using. No issues with any other connections on any other devices so I'd rather try specific fixes for this one ethernet connection if possible.
- plemansFeb 08, 2022Guru - Experienced User
I've been on the newer firmware for a while and its worked well on my system.
Not saying you should try it but there's not much to change in the settings for the satellite if one is working and the other not.
You can try reinstalling your current firmware version in case it is corrupt.
Thanks. Will try resetting the satallite and have a mess around with the ethernet settings on the windows machine. See if I can sort it without having to change too much for the rest of the network.
