atalanta77
Jun 17, 2021Follower
Ethernet port not working on RBK352 router
Hi
Located in Australia and just purchased the RBK352 mesh system.
Wifi works fine on both router and satellite units. Ethernet works great on the satellite however no internet from any of the 3 ethernet ports on the router.
Have unplugged, restarted and replugged a few times. Have tried different cables and still nothing when it comes to ethernet on the router.
Is there a specific setting on the router that I need to change? Anything else I can try before taking it back to the shop?
Thank you
1 Reply
Possible the RBR is faulty, contact NG support and ask about a RMA or return the system to place of purchase and get another set.
