thirtysomething
Jan 23, 2023Aspirant
Ethernet port numbering on CBR750
If I am looking at the back of the AP. From Right to left Cable - Coax Power then Ethernet 1? 2,3,4 or reverse numbering?
Jan 23, 2023Guru - Experienced User
I believe its 1 nearest the coax connector. You could check this by connecting something to each LAN port and log into the CBRs web page and on the Advanced Tab select the show stats button. Review the connection listed on each LAN port seen on this window. Unless your changing to bridge mode, not really important as the LAN ports are all on same network.
thirtysomething
Yes, thank you, it was actually opposite. ethernet 1 is on the far side. I need to grab a packet capture. I thought I read it would mirror to Ethernet port 1. Do you know if that is true? The menu is Enable LAN/WAN Packet Capture and Start Capture
- FURRYe38Jan 23, 2023Guru - Experienced User
Technically since the CBRs don't have a WAN Port. Not sure if that feature actually works on the CBR since the ISP connection comes in on the coax connector.
