thirtysomething
Jan 23, 2023Aspirant
Ethernet port numbering on CBR750
If I am looking at the back of the AP. From Right to left Cable - Coax Power then Ethernet 1? 2,3,4 or reverse numbering?
thirtysomething
Yes, thank you, it was actually opposite. ethernet 1 is on the far side. I need to grab a packet capture. I thought I read it would mirror to Ethernet port 1. Do you know if that is true? The menu is Enable LAN/WAN Packet Capture and Start Capture
Jan 23, 2023Guru - Experienced User
Technically since the CBRs don't have a WAN Port. Not sure if that feature actually works on the CBR since the ISP connection comes in on the coax connector.
