atalanta77
Jun 17, 2021Follower
Ethernet ports not working on RBK352 router
Hi Located in Australia and just purchased the RBK352 mesh system. Wifi works fine on both router and satellite units. Ethernet works great on the satellite however no internet on any of the ...
- Jun 17, 2021
Netgear has set up a community forum specifically for the Orbi AX product. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-axPossible the RBR is faulty, contact NG support and ask about a RMA or return the system to place of purchase and get another set.
Thank you.
Jun 17, 2021Guru - Experienced User
Thank you.
