R2dTOO
Oct 18, 2022Guide
Ethernet Ports Not Working on RBR750 or RBS750
I have an RBR750 and 1 RBS750. The ethernet ports are not working on either device. I've rebooted both devices, and installed the latest firmware (V4.6.9.11_2.3.5). I've also test with several differ...
CrimpOn
Oct 18, 2022Guru - Experienced User
There is no option to enable/disable Ethernet ports on the router or satellite.
- CrimpOnOct 18, 2022Guru - Experienced User
Did these Ethernet ports function correctly at one time, and no longer function?
Or, is this the first time something has been connected to them?
What sort of device is being connected?
