R2dTOO
Oct 18, 2022Guide
Ethernet Ports Not Working on RBR750 or RBS750
I have an RBR750 and 1 RBS750. The ethernet ports are not working on either device. I've rebooted both devices, and installed the latest firmware (V4.6.9.11_2.3.5). I've also test with several differ...
Oct 18, 2022Guru - Experienced User
Has a factory reset and setup from scratch been performed since last FW update along with a full power OFF of the RBR and RBS for 1 minute then back ON?
R2dTOO wrote:
I have an RBR750 and 1 RBS750. The ethernet ports are not working on either device. I've rebooted both devices, and installed the latest firmware (V4.6.9.11_2.3.5). I've also test with several different network cables. I've read online that there is an option in the settings to disable the ports, but I haven't found that. Can anyone point me in the right direction?
