Cryptok
Jul 10, 2022Initiate
Ethernet ports suddenly stopped working on RBR750
Bought 6 months ago to the day, been working fine without issue. Suddenly today, I can't connect any of my PC's that are hardwired to the RBR750 router. Wifi works fine on all devices. I tried bypass...
Cryptok
Thanks for reply, answers to questions below - (issue not fixed):
1. Yes, using all CAT6 cables.
2. Cable modem: Netgear CM600
3. Followed all your instructions exactly, and at no point in the steps was I able to get an IP address over ethernet port. Disconnected all RBS, other cables, modem, etc. Did 1 min reset. Tried all 3 ethernet ports. At last step, did the factory reset and re-setup the RBR. Wifi back up and running, but still no ethernet access, back to where I started.
