Dumbdad79
Feb 06, 2024Aspirant
Every time I do a factory reset and try to use my original ssid name the router disconnects
Hi, I am currently spinning my wheels with a similar issue to this right now. Every time I do a factory reset and try to use my original ssid name the router disconnects. It does the same thing when...
- Feb 07, 2024
THanks for checking that. Odd way of making that work.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
CrimpOn
Feb 06, 2024Guru - Experienced User
Disconnects in what way?
- Drops the connection to the internet?
- The instant Apply is clicked, the web connection to the router closes?
- Dumbdad79Feb 06, 2024Aspirant
As soon as I apply my original SSID the wifi connection to the router drops. If I change it to anything else it works fine.
