Dumbdad79
Feb 06, 2024Aspirant
Every time I do a factory reset and try to use my original ssid name the router disconnects
Hi, I am currently spinning my wheels with a similar issue to this right now. Every time I do a factory reset and try to use my original ssid name the router disconnects. It does the same thing when...
- Feb 07, 2024
THanks for checking that. Odd way of making that work.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Dumbdad79
Feb 07, 2024Aspirant
Fixed! I changed the security to "None" and then was able to login with my phone. Then I turned the security back on to wpa2. Now it's working and all my devices are connected.
Feb 07, 2024Guru - Experienced User
Enjoy. 📡
