goodew
Aug 01, 2022Aspirant
Expansion Network rbk852, IOS
Hi I have a network RBK852, 1 router, 1 satellite. I have a "almost dead" corner in my living room, hardly WifFi signal. Q1: Is itl possible to expand the network with an extra satellite? Q2 If...
- Aug 01, 2022
Ya add a RBS via ethernet connection in this area of the home for coverage:
goodew
Hi
Additional info
V4.6.3.16_2.0.51 (not able to update)
Mfr: Compal Broadband Networks Inc.
Model: CH7465LG-ZG (Not Sure, is only identification on Modem)
S/N. DDAP53222980
Groundfloor 100 m2 ~ 1075 Sq Ft
First floor 60 m2 ~ 646 Sq Ft
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS
to begin with depending upon building materials when wirelessly connected.
Router (Living Room, GF) and Satellite (Study, 1st Fl, ~8 meter from Router, works well) are located at the front of our house.
The dead corner is at the back of our house ~ 12 meter away from the router, behind two half stone brick walls.
Wim
Aug 01, 2022Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first if you haven't already.
Stone brick walls will be problematic for any wifi signals
