goodew
Aug 01, 2022Aspirant
Expansion Network rbk852, IOS
Hi I have a network RBK852, 1 router, 1 satellite. I have a "almost dead" corner in my living room, hardly WifFi signal. Q1: Is itl possible to expand the network with an extra satellite? Q2 If...
- Aug 01, 2022
Ya add a RBS via ethernet connection in this area of the home for coverage:
Aug 01, 2022Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first if you haven't already.
Stone brick walls will be problematic for any wifi signals
goodew
Thanks!
I have option #2 already operational from the begining; all Wifi bands shut off.Orbi Router is the only Router.
This causes the weak/dead spot in my house...checked it with NetSpot best Signal ~ -85 / -90 dB
My Apple TV doesn't work properly due to bad signal
So,.... best solution?
Install extra Satellite? possible with cable?
Just install switch and connect all devices with cable? direct cable to modem available
