goodew
Aug 01, 2022Aspirant
Expansion Network rbk852, IOS
Hi I have a network RBK852, 1 router, 1 satellite. I have a "almost dead" corner in my living room, hardly WifFi signal. Q1: Is itl possible to expand the network with an extra satellite? Q2 If...
- Aug 01, 2022
Ya add a RBS via ethernet connection in this area of the home for coverage:
goodew
Thanks!
I have option #2 already operational from the begining; all Wifi bands shut off.Orbi Router is the only Router.
Stone brick walls will be problematic for any wifi signals
This causes the weak/dead spot in my house...checked it with NetSpot best Signal ~ -85 / -90 dB
My Apple TV doesn't work properly due to bad signal
So,.... best solution?
Install extra Satellite? possible with cable?
Just install switch and connect all devices with cable? direct cable to modem available
Aug 01, 2022Guru - Experienced User
- goodewAug 02, 2022Aspirant
Thans for you support and advise
- FURRYe38Aug 02, 2022Guru - Experienced User
Enjoy. 📡
