fanzai
Sep 14, 2020Aspirant
Extend existing ORBI RBK853 Wifi mesh network
Hello, I made a mesh network with the new RBK853 WiFi6. I need to install an additional satellite. What are the various options compatible and available? Thanks so much.
fanzai
Thank you for the replies.
I don’t really need AX in that zone of my house. I just need a stable signal when i am in those rooms. That’s why i was asking for a compatible solution (also cheaper than AX6000 satellite).
All my satellite are wired with the router: could you please link me the product you are talking about? Thank you
Sep 14, 2020Guru - Experienced User
You can try a EAX80 and see if this will connect for you. They are about $250. I know my EX7500 and 7700s do but those are AC extenders.
