Retired_Member
Apr 05, 2020Extend RBK852 with RBS20s
Hello I am just about to buy a RBK852 kit but are a litle worried after reading threads here. Today I have a RBK52 with two extra RBS20s, doing almost the job except for handling the Gigabit ...
- Apr 05, 2020
Yes, you can connect the RBS20 satellites wired to the new RBR850 router. Wireless support will come later.
Disney Circle is not yet supported in the new Orbi AX but should come soon, I hope.
Meanwhile you can use the site blocking and blocking schedule in the web GUI for parental control.
ekhalil
Apr 05, 2020Master
Retired_Member
Apr 05, 2020Thank you, then I will go for this.
Just hope the new config will be as stable as the old one.
