andrews1218
Jul 24, 2023Tutor
Extender EX7500 RBR850
Hi I have a orbi RBR850 plus one RBS850 and I am trying to extend to my outdoor patio. I just got a EX7500 which stated it was compatible however I do not see the 5ghz network extending, it doesn't ...
- Jul 26, 2023
the EX7500 is a triband extenders. Meaning one of the 5ghz band will use the lower channels and one the higher channels. So you should still be able to set it up fine. Just use the installation assistant.
It is also a mesh extender so it might just be how you're scanning the wifi to see it. If the onewifi name is enable, a standard wireless scanner will only pickup one ssid.
Jul 24, 2023Guru - Experienced User
What channels are you using one the RBR?
The EX7500 should work and connect with 5Ghz.
Try channels 1 and 40 on the RBR and see if the EX will connect. I know I tried mine once before and it connected. I didn't get a chance to test it for a long period of time.
Make sure the FW on the EX is up to date.
andrews1218
Jul 24, 2023Tutor
I dont have those channels on my RBR850, I have the higher channels over 149 only. I also have a EAX15 and that seems to work okay but doesn't handle that many devices.
- FURRYe38Jul 24, 2023Guru - Experienced User
Orbi AX systems including the 850 only allow for the lower 5Ghz channels that users can change. So 36,40,44 and 48 can be seen on the RBR. All higher channels are hidden and used by the Orbi's wifi backhaul system between the RBR and RBS only. Users can not change these channels.
- andrews1218Jul 24, 2023Tutor
Sorry thats what I meant I only have the lower channels on the RBR and higher channels on the EX7500. I am going to return it and probably just get another RBS850 was just hoping there was something cheaper I could do to extend it since it is such a small portion of coverage.
If you set the EX up in extender mode the EX will auto tune to those channels being used on the RBR.
