Iwzbravo
Feb 23, 2023Aspirant
Extending Wi Fi Range
The people that I am living with decided to put the internet in the basement so I bought the ax4200. The primary router is with the modem in the basement and I have the satellite set up on the second ...
Feb 23, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Is the RBR in the basement as well? Basements are not recommended locations for the main RBR. All that concrete and steel will cause problems.
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰️
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
