mcs012377
Mar 06, 2021Follower
Extending Wifi to roof
I live in a tall, skinny, city home and I’m trying to extend my WiFi signal to my roof deck. I have 3 floors and a roof deck. Floor 1: kitchen + living room. Floor 2: home office + bedroom. Floo...
titaniumrx8
Jun 19, 2021Apprentice
Is there a power outlet on your rooftop deck? If yes then get a pair of ethernet over power adapters. Plug the nearest satellite into the adapter and plug a wifi router into the adapter on the roof. Depending on your home wiring it might not work but worth a try.
The adapters work best if they are plugged into outlets on the same circuit breaker.
