phoxphyre's avatar
Jan 31, 2023
External IP Filtering
Does the Orbi RBR750 (or any newer Orbi models) have the ability to block all external IP addresses unless I allow it? For example, I have a major Brute-Force-Attack on an SSH port that I must have open for one external connection, but the attacks are daily. If I could set the IP that I would like to allow and block all others, that would be ideal.
Thank you in advance for any assistance or advice,
  • CrimpOn's avatar
    CrimpOn
    I think the answer is, "No."  The passes packets to the designated local IP address and it is up to the receiving device to accept or reject them.  What sort of machine is SSH running on? (Windows? Linux? Mac? NAS?)
    • phoxphyre's avatar
      phoxphyre
      Tutor
      Thank you for your response. It is the Apple M1 Max Mac Studio, 32 GB ram running Ventura.
