stu3886
Sep 28, 2021Apprentice
Facebook and Instagram not loading on WiFi
 When connected to orbi wifi using the mobile app for facebook and instagram on my phone it fails to load images and videos and when they do its extremely slow, when I switch to mobile data it loads w...
- Aug 10, 2022They did work in AP mode but I needed to roll back to an older firmware and block all updates. This worked great but eventually, a change would happen and the update would get pushed randomly at night and I would have to waste time rolling back again. The problem was I had an ISP-provided router so I was getting double NAT if I used the Orbi in router mode. I changed my internet to FTTP so I had an ONT installed with this. I connected the ONT to my orbi directly and used the orbi as the router. no double NAT and everything appears to be working ok.
stu3886
Unfortunatly sky q hub doesnt allow you to change the DNS on the router. i have tried changing the DNS on my mobile but that didn't make any difference.
I tried the orbi in router mode and the facebook and Instagram loading issue went away but then I had the issue of Double NAT.
I also tried disconnecting the orbi and turning on the sky q hub wireless to connect directly and that worked as well. so it seems like the issue is related to the orbi
Sep 28, 2021Guru - Experienced User
So put the orbi in router mode and put the orbi's ip address into the skyhub's DMZ.
See if that works
- stu3886Sep 28, 2021Apprenticetried it with the DMZ but i get Double NAT is there anything else that can be changed/checked when the orbi is in AP mode? - plemansSep 28, 2021Guru - Experienced UserIn AP mode, the sky hub is handling all the routing. Is there anyway for the skyhub to be put in passthrough/modem only mode? - stu3886Sep 28, 2021Apprenticesadly not, sky dont allow modem only on their routers :( I have tried with an asus router in AP mode and it all works perfectly, so it definitely seems like its an orbi specific issue. I also don't have the ability to downgrade the firmware from the current V4.6.3.16_2.0.51
