stu3886
Sep 28, 2021Apprentice
Facebook and Instagram not loading on WiFi
When connected to orbi wifi using the mobile app for facebook and instagram on my phone it fails to load images and videos and when they do its extremely slow, when I switch to mobile data it loads w...
- Aug 10, 2022
They did work in AP mode but I needed to roll back to an older firmware and block all updates. This worked great but eventually, a change would happen and the update would get pushed randomly at night and I would have to waste time rolling back again.
The problem was I had an ISP-provided router so I was getting double NAT if I used the Orbi in router mode.
I changed my internet to FTTP so I had an ONT installed with this. I connected the ONT to my orbi directly and used the orbi as the router. no double NAT and everything appears to be working ok.
stu3886
Oct 08, 2021Apprentice
So the original issue is still happening.
But a further update in my troubleshooting. If I switch over to the guest wifi the problem goes away!
It’s definitely an orbi issue not an ISP issue
alexwatson564
Aug 10, 2022Aspirant
Try these things:
- Reset your wi-fi connection.
- Check Instagram running status on DownDetector
- Clear the cache and data on Instagram and Facebook.
- Don’t use a VPN to access Instagram
- Install the app again.
- Remove yourself from the Beta program.
- Try Browser-based access.
If nothing works for you then perhaps this problem is caused by IPV6. Try to disable IPv6.
- stu3886Aug 10, 2022Apprentice
Unfortunately, I never did resolve the issue.
The only fix was to turn off AP Mode and use it in router mode. So far so good.
- FURRYe38Aug 10, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
