stu3886
Sep 28, 2021Apprentice
Facebook and Instagram not loading on WiFi
 When connected to orbi wifi using the mobile app for facebook and instagram on my phone it fails to load images and videos and when they do its extremely slow, when I switch to mobile data it loads w...
- Aug 10, 2022They did work in AP mode but I needed to roll back to an older firmware and block all updates. This worked great but eventually, a change would happen and the update would get pushed randomly at night and I would have to waste time rolling back again. The problem was I had an ISP-provided router so I was getting double NAT if I used the Orbi in router mode. I changed my internet to FTTP so I had an ONT installed with this. I connected the ONT to my orbi directly and used the orbi as the router. no double NAT and everything appears to be working ok.
Aug 10, 2022Guru - Experienced User
So FB and IG are now working for you with orbi in router mode?
stu3886 wrote:
Unfortunately, I never did resolve the issue.
The only fix was to turn off AP Mode and use it in router mode. So far so good.
stu3886
Aug 10, 2022Apprentice
- FURRYe38Aug 10, 2022Guru - Experienced UserGlad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
 Enjoy. 📡
