Orbidude
Jun 01, 2024Guide
FaceTime freezing every now and then
Hello, I recently inquired in another forum about upgrading from my 850 series (router and 2 satellites) to the 970 series just to have the latest technology. I was advised against it because the...
Jun 01, 2024Guru - Experienced User
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Armor, Smart Parental Controls or Circle, IPv6 and Traffic Meter.
Try enabling SIP ALG under routers web page under Advanced Tab/WAN Setup.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Orbidude
Jun 02, 2024Guide
FURRYe38, here are my results regarding your questions.
>>> Armor, IPv6 and Traffic Meter are disabled. I can’t seem to locate Smart Parental Controls or Circle.
>>> SIP ALG is disabled.
Thanks!
