Dazza762
Jan 12, 2022Luminary
Factory reset Orbi system
I want to do a full reset of my RBK753 system. Will erasing the router config in the admin website interface also wipe the attached satellites? The manual doesn't specify. I basically want to set the...
Dazza762
But they won't have been wiped along with the router? I'd like to get them all back to out of the box settings.
Jan 12, 2022Guru - Experienced User
You can always reset them as well if you'd like to ensure they're wiped.
They've got a reset button.
- Dazza762Jan 12, 2022Luminary
Yes, I've used the on device reset buttons on the satellites but noticed they were still showing on the admin page with the names I'd given them so assumed they hadn't been full factory reset.
- FURRYe38Jan 17, 2022Guru - Experienced User
How are you resetting the RBR? Reset button or ERASE button on the RBRs web page?
- Dazza762Jan 17, 2022Luminary
FURRYe38 wrote:How are you resetting the RBR? Reset button or ERASE button on the RBRs web page?
Dazza762 wrote:Yes, I've used the on device reset buttons on the satellites but noticed they were still showing on the admin page with the names I'd given them so assumed they hadn't been full factory reset.
Erase on the admin web page.
