Dazza762
Jan 12, 2022Luminary
Factory reset Orbi system
I want to do a full reset of my RBK753 system. Will erasing the router config in the admin website interface also wipe the attached satellites? The manual doesn't specify. I basically want to set the...
Jan 12, 2022Guru - Experienced User
You can always reset them as well if you'd like to ensure they're wiped.
They've got a reset button.
Dazza762
Yes, I've used the on device reset buttons on the satellites but noticed they were still showing on the admin page with the names I'd given them so assumed they hadn't been full factory reset.
- FURRYe38Jan 17, 2022Guru - Experienced User
How are you resetting the RBR? Reset button or ERASE button on the RBRs web page?
- Dazza762Jan 17, 2022Luminary
FURRYe38 wrote:How are you resetting the RBR? Reset button or ERASE button on the RBRs web page?
Dazza762 wrote:Yes, I've used the on device reset buttons on the satellites but noticed they were still showing on the admin page with the names I'd given them so assumed they hadn't been full factory reset.
Erase on the admin web page.
Ok, Are you pressing the reset button on the RBS prior to use the ERASE on the RBR? I Found that resetting the RBS first, then when the front starts to blink white, turn OFF the RBS. Then go to ERASE on the RBR. ALL should be gone from the RBR.
What browser are you using? I use MS edge mostly for initial set ups and ERASE.
