Chuck_M
Oct 01, 2020Mentor
Factory Reset Procedures
My AX6000 had been working pretty solid for months. Back in July I started having log issues as well as the internal speed test stopped working on both the web gui as well as the app. this may have...
- Oct 01, 2020
Annomalies maybe seen if you graduate FW versions to another and you created backup files on previous versions of FW. The is always a small risk here. You shouldn't see any annomalies while using backup files in the same FW version.
Oct 01, 2020Guru - Experienced User
Advanced tab/Advaced/Admiistration/Backup Settings/Backup should be used for backing up the RBR. This saves time if a reset is needed. You can have several backups as well. In stages. Clean backup with nothing configured or enabled, one with configurations. One with Armor enabled, AP mode configuration, etc.
- Chuck_MOct 01, 2020Mentor
I was under the (misunderstanding) that a backup could carry forward anomalies... (e.g. internal variables - not to be confused with GUI settings.) Is that not true?
Thanks for clarification if so.
- plemansOct 01, 2020Guru - Experienced User
I think FURRYe38 is just stating you can do multiple backups. One with each of the settings/ configurations you want.
I've had people on here that had devices work find until backups were restored. Its why I usually recommend a manual install process if there's any issues with firmware.
- FURRYe38Oct 01, 2020Guru - Experienced User
