Chuck_M
Oct 01, 2020Mentor
Factory Reset Procedures
My AX6000 had been working pretty solid for months. Back in July I started having log issues as well as the internal speed test stopped working on both the web gui as well as the app. this may have...
- Oct 01, 2020
Annomalies maybe seen if you graduate FW versions to another and you created backup files on previous versions of FW. The is always a small risk here. You shouldn't see any annomalies while using backup files in the same FW version.
Oct 01, 2020Guru - Experienced User
it does stink having to do the manual rebuild process. Especially when you're resetting or replacing the router frequently. At least monthly I'm changing something out and its caused me to streamline/limit how much advanced routing features I use.
but the idea's a good one in having something like a full backup option or partial backup. I have no idea how implementing something like that would go though :)
and sadly, we'd still end up telling people that they could try that backup option and if it didn't help to go back to the full manual install.
