JayLa86
Nov 02, 2020Aspirant
Fake advertised speeds Orbi RBR850
Hello, We recently purchased the RBK853 AX6000 system to provide coverage for my home which is roughly 6,500sqft. We've updated the current firmware and done a factory reset from the start. Now I...
JayLa86
Nov 09, 2020Aspirant
On a good day it'll would show 866.78Mbps, however it varies from 50-800Mbps.
Nov 09, 2020Guru - Experienced User
Well this is what I'm seeing with a ASUS GT-AX1100 in wireless bridge mode:
Line of site and about 20feet away from the RBR.
- JayLa86Nov 10, 2020Aspirant
Appreciate the input, however any Netgear reps care to chime in? Did I just throw over 1k worth of routers down the drain?
- MstrbigNov 10, 2020Master
JayLa86 wrote:Appreciate the input, however any Netgear reps care to chime in? Did I just throw over 1k worth of routers down the drain?
Slow wireless speeds can be caused by interference. Wiring, WIFI channel setting, walls, router and satellites placed too close to other F devices, distance between satellites and routers all play a role in interference. I would first check you WIFI channel settings, as you mentioned earlier that your speeds fluctuate drasticly.
- FURRYe38Nov 11, 2020Guru - Experienced User
NG doesn't commonly comment in forum posts. I recommend you open a support ticket with NG support and make contact with them directly and ask for additional help and information.
