HarryBe
Jan 21, 2022Aspirant
Fast Ethernet - Slower WiFI - Orbi RBR750/RBS750
Running RBR750 (drop down wouldn't let me choose). At router via ethernet (direct from Frontier gateway) I'm getting published speeds of ~500mbs. On iPhone 12 pro and MacBook Air, getting much slow...
Jan 22, 2022Guru - Experienced User
I know it sounds stupid but it doesn't say if you're connected to 2.4ghz or 5ghz.
2.4ghz is much much slower. If you're hitting 200mbps over 2.4ghz, thats actually blazing fast for 2.4ghz.
Not as much for 5ghz.
HarryBe
Jan 22, 2022Aspirant
Good question - it is connected to 5Ghz. See below.
I also see the link rate is 864mpbs. Assuming that is between the router and the satellite?
Should be faster than hell on that satellite with that link rate...
- plemansJan 23, 2022Guru - Experienced User
You might try this version of the firmware:
