HarryBe
Jan 21, 2022Aspirant
Fast Ethernet - Slower WiFI - Orbi RBR750/RBS750
Running RBR750 (drop down wouldn't let me choose). At router via ethernet (direct from Frontier gateway) I'm getting published speeds of ~500mbs. On iPhone 12 pro and MacBook Air, getting much slow...
HarryBe
Jan 22, 2022Aspirant
Good question - it is connected to 5Ghz. See below.
I also see the link rate is 864mpbs. Assuming that is between the router and the satellite?
Should be faster than hell on that satellite with that link rate...
Jan 23, 2022Guru - Experienced User
You might try this version of the firmware:
