KQSPRING
Aug 14, 2023Aspirant
FAST FIBRE SIGNAL DROPPING/CLASHING WITH RBRE960
Hi, we have had the RBRE960 with two satellites for over a year now. Worked great as a separate router plus two satellites alongside a full fibre with BT router at our house. Provided excellent consi...
KQSPRING
Thank you so much for your comments.
I have located the option for putting the Orbi router into AP mode within my router settings, I just wondered firstly whether my satellites will still work with the Orbi router in AP mode and secondly is it as easy to switch back to router mode if this doesn't help?
Thanks again
CrimpOn
Aug 14, 2023Guru - Experienced User
Yes, and Yes. Switching modes means:
- In router mode, the Orbi will create a LAN that has a private IP address space that is different from the IP subnet that the ISP assigns to the Orbi router. When the Orbi is connected directly to the ISP modem (or ONT), the router will be assigned a public IP address, and will create a LAN using 192.168.1.x
If the Orbi is assigned an IP in 192.168.1.x by the ISP router, then it will switch the LAN subnet to 10.0.0.x
This is often confusing to customers. - In Access Point (AP) mode, the ISP router assigns IP addresses to the Orbi, the satellites, and every device that is connected to the network.
Some ISPs use 192.168.1.x for their LAN assignments. Others use 192.168.0.x, in which case the Orbi is free to use 192.168.1.x
Honestly, my first step would be to remove the Talk Talk router, connect directly to the fiber ONT, and enter the user name and password that support gave you.
- KQSPRINGAug 15, 2023Aspirant
Thank you, that is great info.
Based on this I shall try the router to the ONT box first. Presumably I need to reset my Orbi router before plugging it in the box and then set up as a new system (otherwise can't see where I would input the login details Talk Talk gave me?)
Sorry in your first message you said that you didn't think the double NAT is the problem, do you have any ideas of what it might be?
- CrimpOnAug 15, 2023Guru - Experienced User
My (personal) opinion is that thousands of customers simply connect their Orbi to whatever the ISP provided and "get on with life". As long as they do not need any of the features that are affected by Double NAT, they remain blissfully ignorant.
However, since Talk Talk support suggested removing their router and connecting directly to the fiber box, I'd certainly want to try that. User Name and password are entered on the first Setup page.
