dbarrow
Sep 01, 2021Aspirant
Fast speed on two computers (480Mbps) slow on all others, phoes, etc. (96Mbps). RBR850, RBS850
I just purchased an RBR850/RBS850 setup. Everything seems to work, but only two wired computers get fas 480Mbps speed, whil EVERYTHING else, computers, phones, tablets, etc. get slightly less than 10...
- Sep 02, 2021
SOLVED! Apparently the slower speed was caused by a poor cable connection in one of our 110 punch down blocks. I am on oxygen, recuperating from Covid (low energy to solve problems or do much physically). I showed my wife how to use a punch down tool and she went up in the attic and "reasserted" all the punch down connections on the terminal strip. Before Orbi, I have seldom intermittant connections, but I did have the occasional issue. I think Orbi is more sensitive to cable/connection quality and downgraded a whole section of our network to 100Mbps. Anyway, all fixed now. Thanks for your help.
Sep 01, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
